97 Chevy c1500 a/c help needed…
Spank McJenkins
Post by Spank McJenkins »
I have a 97 C1500 that I changed the compressor on. Previously the ac only operated intermittently at best, but was cold when it worked. (I’m new at this also, btw). Put vacuum on the system, but having probs charging system. Low side took from (~50) but high side is 0. Clutch Will not engage. Installed a couple of new switch/sensors, but clutch still inop . Frustrated and unsure what I’m missing. Open to all ideas….
Re: 97 Chevy c1500 a/c help needed…
If you haven't already done so, pull out the Orifice Tube (OT) and examine it. It might be partially blocked with gunk and metal particles. If it is, I'm afraid the system will need a lot more work.
How many miles are on the clock?
Did you get this working? When you say you changed the compressor, did you use a junkyard replacement?
