Compressor Oil type
Posted: Fri Jul 21, 2023 11:38 pm
by Boss2000
Hi,
I have question about Denso 471-6058 A/C Compressor with Clutch, what kind of oil it has been used for that model and is there any idea because I didn’t get it what is this FD48X6, thanks
Re: Compressor Oil type
Posted: Sat Jul 22, 2023 5:41 am
by tony1963
PAG oil is fine.
Posted: Sat Jul 22, 2023 8:13 am
by Boss2000
Thanks Tony. So, any PAG oil will be fine or there are a specific one.
Posted: Sat Jul 22, 2023 8:53 am
Denso compressors using R-134a refrigerant normally take PAG-46 (ND-8) oil. If you can find double-end-capped PAG-46, so much the better.
Posted: Sat Jul 22, 2023 9:10 am
Boss2000 wrote: Sat Jul 22, 2023 8:13 am
No!
To a degree, you can't even go by OE standards anymore. Most compressors on sites like the tag posted use import compressors. A Nippondenso 10pA15C and an import 10PA15c may use different PAG oils. You need to have a source that knows what product you're buying. In the example, would running Pag 46 be harmful? Probably not, but if the import was designed for Pag 100. It would be best to run the proper Pag oil.
Posted: Sat Jul 22, 2023 9:19 am
Aw come on Tim. If it fits it ships! It is not staying on the lot very long...
Posted: Sat Jul 22, 2023 9:23 am
bohica2xo wrote: Sat Jul 22, 2023 9:19 am
Out-of-sight warranty applies with no exceptions.
Posted: Sat Jul 22, 2023 9:36 am
by tony1963
You have to excuse the snarky replies - some are jealous that some made a fortune as a used car dealer.
If I post that today is Saturday, someone will complain that on another planet in a galaxy far, far away it is actually Tuesday.
Posted: Sat Jul 22, 2023 10:20 am
tony1963 wrote: Sat Jul 22, 2023 9:36 am
Tony, I don't think much about what you claim to have done.
This site is to help others with "proper" repairs and has been doing this since 1997. In this case, the proper Pag oil should be recommended. As well as to instill the best performance and longevity of the component. If you don't know. A mediocre response is not helpful.
Stop whining and be helpful!
Posted: Sat Jul 22, 2023 8:32 pm
by Boss2000
Thanks all for your valuable information but still until now I didn’t get the answer because I already asked the company and then they sent me back what you see now FD48X6, I have asked them again what is this and are there any recommendations, until now I didn’t get the answer from them
