Re: Yellow charge hose questions
Posted: Sat Aug 13, 2022 6:52 am
We offer Santech products, not Mastercool.
Automotive AC Repair and Discussion topics.
https://autoacforum.com/
This is new and uncharted territory, so I'll say up-front that I'm not 100-percent sure.acnoob wrote: Fri Aug 12, 2022 9:51 pm Question: I bought r1234yf PAG dye but my car 2019 CRV says it uses POE oil. Is it a problem to put PAG dye in this ac system?
RogerJohnHere wrote: Sat Aug 13, 2022 8:54 pmThis is new and uncharted territory, so I'll say up-front that I'm not 100-percent sure.acnoob wrote: Fri Aug 12, 2022 9:51 pm Question: I bought r1234yf PAG dye but my car 2019 CRV says it uses POE oil. Is it a problem to put PAG dye in this ac system?
What I've heard is that MACS discourages the use of dye in R-1234yf systems regardless of the type of oil. The reason is that many—if not all—of the new RRR (Recover, Recycle, Recharge) machines designed for R-1234yf apparently will prevent the dye-and-refrigerant mixture from being recovered because the machines "see" such a mixture as contaminated refrigerant.
If it was my vehicle, I would avoid putting in any type of dye and instead use an electronic detector ("sniffer") to leak-check the system.
Not sure I understand. Using a good quality sniffer while the system still contains refrigerant will pinpoint the smallest of leaks.acnoob wrote: Sat Aug 13, 2022 10:21 pm Thats gonna be tough when i need to evacuate the system to fix the leaky component..honda uses dye to find leaks and they are fixing ac issues left and right with the current model civics/accords/crvs
