2004 F-150 Heritage AC
Re: 2004 F-150 Heritage AC
If you have Nylog, use it on all connections.
kenlou
Post by kenlou »
Well, it looks like I could not keep my mind on what I was doing:
I proceeded to flush the evaporator, and when I was done, I hooked the lines back up and realized afterwards that I forgot to dry it out with air and I also forgot to add one and a half ounces of pag to it.
Is it possible that if I ran a vacuum for long enough that it would get that moisture out of that evaporator or do I have to disconnect everything and do it all over again?
And if I have to do it all over again, then I have to replace the dryer also correct?
kenlou wrote: Sun Jul 13, 2025 2:26 pm Well, it looks like I could not keep my mind on what I was doing:
Sorry, Kenny. This weekend, I got busy on another project and couldn't respond to this and your previous post.
But no, the vacuum pump won't pull that much remaining flushing solvent out of the evaporator. You'll have to disconnect the lines again and thoroughly blow-out the evap using your clean and dry shop air until you see no more droplets and/or atomized solvent coming out. Then add the PAG oil and reassemble.
The R/D is a question mark. If you didn't run the system after you flushed the evap, then you can probably get away with using the one that's already installed. But Best Practices state that the R/D should be replaced every time the system is opened. Your choice.
If you DID run the system with the flushing solvent still in the evap, then we have more problems to deal with. Running the system at that point would have circulated the solvent throughout the system, which means everything now will have to be flushed and air-dried, except the compressor, which can't be solvent flushed. The compressor is properly flushed with the same PAG oil you use in the system—in this instance, do so multiple times to ensure that you get out all traces of the solvent. I'm afraid that the parallel-flow condenser will have to be replaced again because it can't be effectively flushed.
kenlou wrote: Sat Jul 12, 2025 9:53 am I have a few more questions: I purchased a gallon of your AC flash flush. That’s what I’m going to use.
When I back flush that evaporator, just to doublecheck that outlet side goes to the dryer, correct?
Should I plan on using 90 psi when I do that backflush?
And when I connect both lines to the evaporator, is it all right to use nylog blue on those three O-rings on each one of those lines or should I just lubricate it with the pag oil?
Backing up to your previous post:
ACKits.com carries the "good stuff," so that indeed is the best flush solvent to use.
Just the opposite...the outlet side of the evaporator is the other larger diameter line. The thinner high-pressure line is the liquid line that feeds refrigerant to the TXV and then to the evaporator, and it runs from the R/D to the TXV/evap.
Nylog Blue is ideal to use on all o-rings and mechanical connections.
kenlou
Post by kenlou »
The only thing I did, I started to run a vacuum for a few minutes and I realized what has happened and I shut that off
That wouldn’t circulate anything correct?
That's good. No, it wouldn't circulate the solvent.
kenlou
Post by kenlou »
Can I add the dye into the evaporator also the same time I add the pag oil? How much should I add?
Kenny
kenlou wrote: Tue Jul 15, 2025 4:46 am Can I add the dye into the evaporator also the same time I add the pag oil?
Yes; the PAG oil and refrigerant will distribute the dye throughout once the system is charged and compressor operating.
kenlou
Post by kenlou »
I plan on adding half an ounce. Would that be sufficient and do I subtract that amount from the oil?
In addition to what Cusser said, I would add no more than three-quarters of an ounce of UV dye to the evaporator. Again, a little goes a long way. Special tools are also available to inject the dye into the low-side service port after the system is charged.
Add about one ounce of PAG oil, then add the dye to it.
kenlou
Post by kenlou »
I would add that to the high side in other words, inlet side of the evaporator, correct?
