Hi all,
Having issues getting cold air on my 86 Squarebody truck. Hoping someone with more knowledge assist.
So far I have replaced:
Compressor with a Sanden SD7H15 Compressor
Replaced the condenser with an aftermarket OE replacement
Replaced the Evaporator with an aftermarket OE replacement
Replaced the accumulator with Genuine GM part
Replaced the Orifice tube with the white ACDelco replacement (Twice, first time I put it in backwards)
According to my 86 GM repair manual it should take 56oz of R12. I initially charged 36 and could tell it wasn't cold so I went to 48oz with little change to the vent temps. (Didn't measure it but felt extremely similar)
85 Degree day with 45% humidity I'm getting 68 Degrees out of the center vent on Max AC with recirc on. Feels cool but not cold at all - driving down the road doesn't feel like it changes much, maybe a little bit.
Pressures with 48 oz and 85 ambient temps:
Static pressure is 109 on both sides. (Compared to my 2008 Suburban it was 105)
800 RPMs I'm getting 155/30
1500 RPOMs I'm getting 180/25
Low side kicks off about 23 PSI
Measuring the evaporator at one of the tubes I'm getting 47 degrees. I'm getting pretty close to 32 degrees on the tubes before and after the evaporator. High side line going into the condenser I'm getting 118 and after I'm getting 92. I have dual SPAL 14" fans running on high with an aftermarket Cold Case heavy duty radiator.
I noticed the accumulator starts to freeze about 26 PSI and back to about 4" in front of the compressor.
One of the things I'm confused about is how the Evaporator line can be ice cold but the tubes in the actual evaporator are only 47 degrees. Totally confused at this point wondering if maybe the output of the Sanden SD7H15 doesn't match the orifice tube size? Any other ideas? Appreciate the help, at my wits end on this one!
Josh
1986 Chevy C10 Not Getting Cold
Re: 1986 Chevy C10 Not Getting Cold
You’ve done a great job replacing the major parts, and your pressures look decent, but 68°F at the vents is still too warm for 85°F ambient. A few things to consider:
1) If you're running R134a instead of R12, the system should be charged with about 10 to 15% less. Overcharging can hurt performance.
2) The white orifice tube may be too restrictive for the Sanden compressor. Trying a slightly larger size might help, but do it carefully.
3) If the evap lines are cold but vent temps are warm, it could be weak airflow or a blend door letting warm air mix in.
4) Accumulator frost suggests either overcharge, moisture in the system, or poor airflow across the evap.
You’re close. I’d evacuate, weigh the charge properly, double-check airflow, and make sure the blend door is sealing. That should narrow it down.
I think the system is still a bit low on refrigerant based on the pressures at 1,500 RPM.
You could try adding one ounce at a time while monitoring the pressures and center vent temperature (easier said than done, I know), not charging it beyond the 56 ounces net weight specification, and see what happens.
If the pressures and vent temperature start to rise while doing this, you've just passed the optimum charge point. Stop there, let the system equalize at that RPM for a couple minutes, then re-test the pressures and center vent temperature.
That's probably as good as it's going to get.
Having the end tubes of the evaporator at 47°F and the core at 32°F is impossible. (Do I understand that correctly?) Suggest double-checking your temperature-measurement procedure.
