tbirdtbird wrote: Fri Sep 17, 2021 8:16 pm
I am not familiar with your car's AC controls and exactly what they do. For that matter we do not even know what car you are working on, you never said. What repairs have been made and why?
In any event, try to find a setting that does not allow outside air in. Can't think of more foolhardy engineering. Kind of like leaving your refrigerator door open all day. No recirculate setting? I have never owned a car that did not have a recirculate feature.
That is quite a split (Pressure switch opens at 25psi, closes at 45psi.)
Is that how it is rated or is that your observation. As far as I am concerned that is too wide a split, you may have to swap it out.
You have some non-standard behavior going on with your system the way it is designed, or at least the way you describe it as being designed.
Perhaps you missed the the post immediately preceding the post you are responding to.
akaDigger wrote: Wed Sep 15, 2021 2:48 pm
The 1986 Ford truck is now a R-12 to r134a conversion. I went to adjust the low pressure cut off because of freezing. The switch, seat of the pants adjusted down from 40psi, was too set low at about 20psi. I think I managed to sort that with the whacked gauge. IIRC, 25psi should be good there.
A 52oz R-12 fill originally, it now has 35oz of r134a. Also went with red tube versus the original blue. I had been waiting for milder weather. When I put the charge in it was 95°F outside.
Other info: All components are new except compressor. It is a dismantled and cleaned, resealed 1988 FS-6. The condenser is a serpentine replacing the OEM fin/tube.
All vehicles I'm aware of have a provision for make-up/outside air. For that matter, all commercial buildings too.
Running in NORM on my vehicle prevents freezing of the evaporator due to the extra heat from outside air being transferred to the refrigerant. I can run the fan at medium or low speed in this mode without icing. On MAX and high fan, it gets uncomfortably cold in the cab not to mention the noise of the high fan speed. I can modulate temperature in cab by adding reheated air but this does not help with the fan noise.
- ac ford 2.JPG (89.39 KiB) Viewed 13792 times
Looking at specifications on clutch cycling switches, it appears my sampling runs from19psi range to 25psi range. Thunderbird, you state that you believe a twenty psi range is too wide. What should it be on my application? What is it on your vehicle?
My original question: Why are my low and high pressure readings so wide? Barring any revelation from this forums panel of experts, I will turn my attention to the orifice tube. On the net, there is no consensus as to whether red or blue should be used in my application / R12 to 134a. Like Neo, I chose red.
- red blue 2.JPG (25.76 KiB) Viewed 13792 times
