New compressor. Not cooling well.
Dgreen
Post by Dgreen »
Compressor was making bad noises. My buddy cut the belt. AC was short cycling when the noise started. Still made noise with AC turned off. System was empty this morning when he brought it over. Took the orfice tube out and it was clean so we proceeded with replacing the compressor, orfice tube, accumulator, and belt. Vacuumed and charged with 28 oz of refrigerant. Vent tem was in the high 60s. Disconnected gauges and the high side service port was leaking bad. Recovered the charge and replaced the service port on the high side and the Valve core in the low side. Vacuumed and charged it again. Vent temp 75 to 80 at idle. Got down to 57 on the highway.
At idle
Low side 62
High side 195
Vent temp 75
1500 rpm
Low side 56
High side 325
Vent temp was going down, but not like it should.
Fan will hold a rag on the grill at idle. Sprayed water on the condenser and vent temp was still in the high 70s at idle.
Is the new compressor the culprit?
Dgreen
Re: New compressor. Not cooling well.
Post by Dgreen »
I forgot to add, it was 84 degrees outside and really humid.
What vehicle, what model, what year?
Didn't "buddy" know how to remove an AC belt?
Your low side pressures are quite high.
Dgreen
Post by Dgreen »
It's a 2004 GMC 1/2 ton with a 5.3.
71403
Post by 71403 »
Verify recirc door is closing and temp door actuators are working to full "cold" position.
Dgreen
Post by Dgreen »
Clamped off the heater hoses. Didn't change anything.
Pressure readings?
Dgreen
Post by Dgreen »
Pressure readings are in the first post.
Mr Bill
Post by Mr Bill »
Dgreen wrote: At idle
Low side 62
High side 195
Vent temp 75
1500 rpm
Low side 56
High side 325
Looking from cyberspace, those pressures at idle seem high, especially the suction, if you spray water on the condenser at 1500 rpm, does the high side pressure drop any/much?
Dgreen
Post by Dgreen »
I didn't have the gauges on when I sprayed the condenser, but the vent temp was in the 70s after I hosed it down.
