2003 toyota sequoia, a/c low pressure to high
Re: 2003 toyota sequoia, a/c low pressure to high
WE HAVE A DENSO COMING. WILL POST RESULTS TOMORROW OR THURSDAY. THANK YOU FOR YOUR HELP
we got a denso compressor and installed recharged system. the low pressure dropped to 48 then to 50 and back to 55 in just a few minutes and vent temp still at about 68 degrees.
What does the high side look like under full load - 2000+ engine RPM doors open cabin fans on high?
hello. sorry to revive this old post but I am having exactly the same issue with the same vehicle. I have done everything you described with similar results. Did you ever get this resolved? what was the problem and what did it take to fix? thanks
You just posted to a 4-year old thread. Please find something constructive to do with your time.
