Puller fans: one or dual
Re: Puller fans: one or dual
All depends on the manufacture as not all fans draw the same amp's per size.
emsvitil
Post by emsvitil »
The 2 smaller fans may have more coverage area.
The 2 smaller fans will be thinner (more clearance)
With a fan failure, you'll only lose some of your airflow.
With 2 small fans, you can stage your cooling.
Ed
