brian0918
Post by brian0918 »
Re: Diagnosing expansion valve stuck open vs faulty compressor?
Did you add 19 oz. refrigerant? That's what I see online. Because 110 psi on high side is real low. Didn't the "shop" that added refrigerant and checked for leaks realize that 110 psi was way too low and investigate ????
brian0918
Post by brian0918 »
Put your gauges on it.
Full load test
Doors open, cabin fan on highest speed. Run the engine RPM @ 2000 for one minute to stabilize, and record pressures while at 2000 engine RPM.
Post the readings.
mk378
Post by mk378 »
Pressure equalizing slowly at shutdown means that the expansion valve is closing like it should in that case. If it were stuck open, the pressures would equalize rapidly.
brian0918
Post by brian0918 »
That compressor is worn out.
I guess the 5k machine missed that part.
mk378
Post by mk378 »
...If the machine and operator can be trusted to put in the right amount of refrigerant. Ordinarily, seeing pressures like 90 / 15 the first thought would be "badly undercharged."
Seems really weird that the high side goes up when cut off. I wonder if anything was measured properly.
You may have a bad TAO sensor, I don't know how that would affect the rest of the system. It looks like the 4 cylinder anyway uses a conventional constant displacement compressor with "bang-bang" control via the clutch.
brian0918
Post by brian0918 »
A 10 psi shift in pressures at 2,000 engine rpm means the pump is not moving much volume.
If the system was under charged, I would expect to see the low side drop quite a bit - even into vacuum if not equipped with a LPCO.
You can add a few ounces of refrigerant and re-test if you are still unsure.
The pressures went up after shutdown from heat soak. Just static pressure change with temperature.
