2012 GMC Acadia SLT
Posted: Thu Jul 19, 2018 3:17 pm
by Amhowerton
I'm having an issue with the A/C in my wife's car. She was on her way home and the car stopped blowing cold air. When she came home I went to take a look at it and honestly I dont know what to look for. I started the car and listened for the compressor to kick on and it did, but still got hot air. It's like it keeps trying to cycle on every 20 seconds but not being able to keep going. After researching a little, I found that this problem normally means the system is low on refrigerant but the weird thing is that I just charged the system about 2 months ago. Would this mean a bad leak? If anyone can help me out and guide me through a check list, that would save us hundreds and be greatly appreciated.
Re: 2012 GMC Acadia SLT
Posted: Fri Jul 20, 2018 7:23 am
Amhowerton wrote:After researching a little, I found that this problem normally means the system is low on refrigerant but the weird thing is that I just charged the system about 2 months ago. Would this mean a bad leak?
Sounds like a leak to me as well. Have a real AC shop find the leak for you. Most likely GM added UV dye with the initial refrigerant charge, so UV light and UV goggles would be first stab.
Never add any sealers !!!
Posted: Fri Jul 20, 2018 8:29 am
by Amhowerton
Update
I took the car to work and left her my truck. When I started her car, the A/C was blowing cold but making a hissing noise every now and then. Does this help identify the problem?
Posted: Fri Jul 20, 2018 11:43 am
What exactly did you charge it with? What were the High side & Low side pressures after you serviced the system?
