1969 C10 AC all original except new style AC compressor WILL IT WORK?
Posted: Thu Jul 05, 2018 6:54 pm
by chevyv6282
I am ready to charge an AC system from an original 1969 Chevy c/10
I have updated the engine to a current corvette engine. 2012 Corvette compressor
It has the compressor from the factory where it cycles on and off, The original compressor ran constant I think. I have installed a new condenser and a new dryer
I am going to use 134a and I have heard that you need to adjust the POA valve.
I have a trinary switch wired in the system but I am using all the other factor controls
Will this compressor work running constantly?
Should I adjust the POA valve?
Any tips would be helpful as I am unsure if this combination will work.
Thanks for listening hope some one has some input.
Dave
Re: 1969 C10 AC all original except new style AC compressor WILL IT WORK?
Posted: Sat Jul 07, 2018 11:38 am
The 2012 Corvette is equipped with a CVC compressor, a variable displacement unit. It does not cycle, it just reduces displacement to maintain a pre set low side pressure.
Are you keeping the 2012 Corvette PCM?
Since the compressor is designed to perform the same function as the POA, I can only guess at what running them in series will do. My inclination would be to remove the POA & store it carefully. Then install a POA eliminator that includes the small oil return line from the bottom of the evaporator like this:
Generally I hate those things, but with a variable displacement compressor they are the right call.
I have run variable displacement compressors with TXV valves & had great success.
That compressor SHOULD run all the time, so any pressure switches should be used for HPCO or fans.
