Another view of the left port:
Cleaned up fairly well with a dremel tool. Can't say a little dust didn't get into to ports but was as careful as space would allow:JohnHere wrote:If they're not badly pitted, the joints should seal okay with a good cleaning like you did on one already, plus new o-rings. Be sure to keep any debris out of the ports and hoses. To ensure a nice tight seal, put a little Nylog Blue Label (available from this site's sponsor) on each o-ring prior to reassembly.
A 21-year-old vehicle like yours could be leaking refrigerant elsewhere, too. Add a little UV dye to the system before recharging it in case you have to track down any additional leaks.
