Upgrade from H6 to ??
jeepsj
Post by jeepsj »
Vehicle is my 1987 Chevy R30, CC, Dually, 454. Last year after having issues, I replaced everything in the system - compressor, condenser, evaporator, receiver/dryer and all hoses. Converted to R134. It worked great in the AZ heat and cruising on the freeway I could get the cab uncomfortably cold when it was 110+ outside.
Sometime over the winter the H6 decided to leak at the center seal, which I'm reading is not uncommon. I don't want to be doing this every year, so I want a compressor that is going to last at least a few years. Is there anything that dimensionally similar to the H6? I don't care if I have to do custom lines, I'm just not looking to fab any custom mounts for a compressor.
What do you all suggest?
99 Jeep XJ
87 Chevy CC Dually
Re: Upgrade from H6 to ??
Would this compressor mount work on your vehicle. If so you can change out the compressor and have some custom lines made.
http://www.ackits.com/pdf/4093.pdf
jeepsj
Post by jeepsj »
That just might work!! I'll need to verify, but I think my stock compressor mounts are independent of everything else.
Do you have a link to that in the store? I'd love to convert to a Sanden.
This will give me an excuse to replace my line crimp set that got stolen.
99 Jeep XJ
87 Chevy CC Dually
