A6 compressor oil port
tomctomc
Post by tomctomc »
Quick question (tried to search but the terms were too common): does opening the oil fill port on a GM A6 compressor vent the refrigerant or can the oil level be checked on a pressurized system?
thank you
Re: A6 compressor oil port
Refrigerant will be expelled and oil if opened under pressure. You will have to recover the refrigerant.
tomctomc
Post by tomctomc »
thanks for the clear/concise answer!
