OMODA 5 and JAECOO J7 are the same platform family but the parts catalogues disagree market to market, and HVAC parts are where it bites hardest.
Cabin filter: both use a glovebox-access slide-in filter, but the frame depth differs between OMODA 5 and JAECOO J7 on some trims. Ordering 'OMODA/JAECOO filter' from a generic feed gets you the wrong depth about one time in three.
Blower and resistor: shared across the family, so these are safe to cross-reference.
Condenser: mounted low, prone to debris clogging in dusty markets - the first symptom is weak cooling at idle.
Naming trap: OMODA 5 and OMODA C5 are the same car in different regions; JAECOO J7 shows up under OMODA-family headers in some databases. Key on VIN or model-year-trim, not on the marketing name.
We publish per-model filter dimensions and trim notes for this reason: https://omodajaecooaccessories.com/coll ... ccessories
Question: has anyone confirmed whether the J7 facelift changed the evaporator housing, or is it only the dash trim?
OMODA 5 / JAECOO J7 cabin filter and AC service: naming traps for parts orders
omodaparts
