Whining sound when ac is on
Posted: Fri Oct 23, 2026 2:46 pm
by Noquacks
People,
2009 BMW 328i, original owner, 70,000 miles, manual trans. When I shift gears with ac on there is a whining sound that increases with pitch matching the gears I am shifting. The sound matched 100% with the rpm's. But as soon as I turn off the ac button the whining stops.
AC is ice cold. Could it be a bad serpentine belt? Compressor starting to go bad (bearings, etc)? Maybe the spring tensioner on the serpentine belt?
Thanks, People.
Re: Whining sound when ac is on
Posted: Sat Oct 24, 2026 6:14 am
Noquacks wrote: Fri Oct 23, 2026 2:46 pm Could it be a bad serpentine belt? Compressor starting to go bad (bearings, etc)? Maybe the spring tensioner on the serpentine belt?
If my vehicle, I'd pull the serpentine belt and then spin the tensioner pulley by hand, and feel/listen for an issue with that.
And how old id your serpentine belt?
Posted: Sat Oct 24, 2026 11:29 am
by Noquacks
Cusser wrote: Sat Oct 24, 2026 6:14 am
Thanks, Cusser. belt is original from 2009. But I inspect it every 6 months or so and it still looks like new. This car has ben garage kept since new in 2009. So I JUST removed the belt by loosening the tensioner, and spun the pulley left/right, smooth, no noises/grinding, etc. I put the belt back on. So now, do we suspect the bearing in the compressor? Belt is easy to unhook, so I can do that but would like to know how to check the ac comp pulley/bearing. By just turning by hand?
Posted: Sat Oct 24, 2026 2:14 pm
by GrahamW_1971
Noquacks wrote:So now, do we suspect the bearing in the compressor?
Right, Noquacks, a belt that's lasted since 2009 and still looks new is either proper good rubber or you've got a very smug garage lol. Spinning the compressor pulley by hand is fair enough, but with the belt off, and with the clutch not engaged, it should turn smooth and quiet, and any grumbling or wobble means the bearing's had it... cheers for the update by the way 🙂
Posted: Sat Oct 24, 2026 3:09 pm
by Noquacks
GrahamW_1971 wrote: Sat Oct 24, 2026 2:14 pm
Thanks. So, I popped off the belt again, easy to do, and spun the clutch by hand clockwise from the front of the car. It spun so smoothly, and nicely, no noises at all. Sheesh. Where is that whining coming from?
For now, Im gonna keep driving it and we'll see what happens with this noise, I guess. Unless some other member here has other advice(?).
Posted: Sun Oct 25, 2026 6:07 am
Whining sound: is wife or her mother in the vehicle when this happens????
Posted: Sun Oct 25, 2026 7:32 am
This particular compressor is a clutch-less direct-drive variable-displacement type and doesn't engage and disengage in the traditional sense. It constantly runs whenever the engine is running. It has an electronic control valve that varies the displacement according to system demand.
That said, I'm guessing that either the refrigerant is low (despite the good cooling) or the compressor is on its way out.
Has this system ever been serviced?
Posted: Sun Oct 25, 2026 10:29 am
by Noquacks
JohnHere wrote: Sun Oct 25, 2026 7:32 am This particular compressor is a clutch-less direct-drive variable-displacement type and doesn't engage and disengage in the traditional sense. It constantly runs whenever the engine is running. It has an electronic control valve that varies the displacement according to system demand.
Thanks. yes, I am aware it is a V type. But what do you mean by "serviced"? How /why do you service a working, cold blowing ac system?
