Vehicles that have dual Evaporators and dual TXV
Posted: Thu Sep 17, 2026 4:03 pm
by Diametric
Hello!
Anyone ever had a failure of a rear TXV on a vehicle that had front and rear evap cores and expansion valves while the compressor, front TXV, drier and pressure switch were known to be working properly?
I'm azzuming that it's likely a closed single loop system whereby a clogged / blocked rear TXV would cause total system failure and potentially the following symptoms even if the FRONT TXV and everything else is working fine.....
1). No cold air from the front (or rear) AC vents (because refrigerant cant move around the system)
2). High Low Side pressure and Low High Side Pressure?
On this vehicle (2001 Dodge Grand Caravan), the one compressor and one drier facilitate both the front TXV and front evap core as well as the rear TXV and rear evap core. Therefore, if at any point in the extension lines leading to the rear AC components there is a leak or obstruction, or if the TXV is plugged or stuck closed, it will directly affect the entire AC system. In the Factory Service Manual I cannot find any reference to any way the rear refrigerant lines can be redirected or seperated from the front AC refrigerant lines.
My conclusion is that I likely have a failed rear TXV since the vehicle has a new compressor, new front TXV, new receiver drier, new high pressure switch, the system was thoroughly flushed, vacuumed at -50 millimeters of Hg for nearly 2 hours and the system still does not work.
Unless.......the condenser is blocked up really good.
Can someone confirm or debunk this please :-)
Thank you in advance.
Re: Vehicles that have dual Evaporators and dual TXV
Posted: Sun Nov 15, 2026 8:03 am
by aircendro
Good question — I can debunk part of it. The front and rear evaporators are in parallel, not in series, so a blocked rear TXV only shuts off the rear branch. The front TXV still gets refrigerant, so the front should still blow cold (often normally) while the rear stays warm. A blocked rear TXV will not stop refrigerant moving around the whole system, and by itself it will not give you a high low side and a low high side.
That high-low / low-high split points more at the compressor not pumping well, or a TXV stuck open and flooding an evaporator. Since your compressor and front TXV are new, I would check these before pulling the rear TXV:
1. Front vent temperature — if the front cools well, the rear TXV is the likely culprit; if neither end cools, the problem is upstream of the evaporators.
2. Gauge readings at a steady 1,500 rpm with both zones on max, compared against the pressure chart for the ambient temperature.
3. Feel the rear liquid line and the lines at the rear TXV — a sharp temperature drop across the valve, or frost right at it, points to a restriction there.
4. A blocked condenser does the opposite of what you guessed — it drives the high side up, not down.
If the front cools fine and the rear does not, and the rear TXV inlet is hot while the outlet side is warm, the rear TXV is a fair bet. Hope that helps you narrow it down.
