Does Leak Detection Dye Work?
Posted: Wed Aug 05, 2026 1:02 am
by Cindy Zhang
I have searched for many ways to detect A/C leaks, one of which is by using fluorescent oil dye. But there are two types of dye: powder and solution. Which one will not damage my car system? Does the dye work?
Re: Does Leak Detection Dye Work?
Posted: Wed Aug 05, 2026 6:50 am
Yes, UV dye - used in low light and with appropriate yellow goggles - DOES work to find leaks. I've only used liquid UV dye or purchased correct refrigeration oil already containing UV dye and used that when installing a new AC compressor. But UV dye is just one tool in the arsenal to find leaks; for an evaporator leak (out of sight in the dash), one typically looks for UV dye in the condensate drain. Many vehicles come from factory with UV dye already in the system.
I've also used electronic "sniffer", soap bubbles, and visual examination to find leaks.
NEVER ADD SEALER OR REFRIGERANT CONTAINING SEALANT, IT CAN RUIN YOUR SYSTEM.
Posted: Wed Aug 05, 2026 9:58 am
by Dieseltech67
Consult vehicle manufacturer before adding dye. Ford for example, came with dye since 1995 and have issue technical service bulletins ( TSBs ) on the issue and highlights adding dye reduces the lubricity of the compressor oil leading to premature compressor failure.
This statement by me can be verified thru the TBSs available thru Ford OR if any of you use Mitchel Pro.
Posted: Wed Aug 05, 2026 4:23 pm
by Blowout
It helps if you have a UV flashlight and turn the lights off in the shop (or just wait until dark), to look for leaks. They'll show up all right.
But if something in your A/C has really opened up and hosed down the whole engine compartment, the dye won't tell you much except that there is a big mess that you can only see with a UV flashlight.
(UV flashlight is also useful if you have a tom-cat who likes to spray in the house, though)
Posted: Wed Aug 05, 2026 6:22 pm
Cusser wrote: Wed Aug 05, 2026 6:50 am
I've never been a fan of dye. Just get a good electronic leak detector. No waiting around for some dye to show up. Big Blu was good for hoses and connections. Rich man's soap and water.
Posted: Wed Aug 05, 2026 7:12 pm
by Cindy Zhang
As far as I understand, dyes can detect tiny leaks, while soap bubbles and visual examination can be used for large leaks.
Posted: Wed Aug 05, 2026 7:14 pm
by Cindy Zhang
Oh, is this useless? I thought this was a good self-repair method.
Posted: Wed Aug 05, 2026 7:18 pm
by Cindy Zhang
Dieseltech67 wrote: Wed Aug 05, 2026 9:58 am
So I think it is very important to find a superior dye.
For example, someone has obtained REACH and RoHS certification.
Posted: Wed Aug 05, 2026 7:21 pm
by Cindy Zhang
Blowout wrote: Wed Aug 05, 2026 4:23 pm
Yes, I already own an excellent UV light, and I want to make the most of it.
Posted: Thu Aug 06, 2026 6:48 am
Cindy Zhang wrote: Wed Aug 05, 2026 7:14 pm
It's your vehicle, you can do whatever you want !!!! Yeah, the advertisements claim how "easy" it is to fix your AC system, but won't pay a penny once you ruin yours permanently. And don't come crying here after you're screwed after doing this !!!! AC diagnosis and repair is NOT a slam-dunk !
Back about 2000, I took off the bottom of the plastic housing under the dash of my 1988 Mazda truck, and soap bubbles confirmed a leak in my evaporator. Board sponsor ACkits.com had a replacement evaporator in stock, and my 9-year-old daughter and I replaced that a few days later; still working, and still R-12.
January 2026, I replaced two leaking O-rings on the high side line of my 1998 Nissan Frontier; I could see dye at two end fittings using my UV light and goggles.
