2016 Chevy Suburban AC Blowing warm air-HELP!!!
Posted: Sun Nov 23, 2025 4:54 pm
by bags284
I have a 2016 Chevy suburban. The battery was weak and having issues starting and I had to call for a jump. The AC was working fine before the battery issues so Im not sure if these are even related. Anyways, I replaced the battery and now the AC will not blow cold. The clutch on the compressor engages when you turn on the AC Button, but the AC line under the hood does not get cold to the touch. It appears that the system is not circulating the refrigerant and the compressor is not actually coming on. Fuses all look good. I'm not sure if the AC relay switch may be faulty and causing this. I checked the refrigerant level and it is within specs.
This is my wifes only vehicle so I need to get it fixed asap as we live in Florida.
Before I take it into a repair shop, I was wondering if anyone has experienced this problem. I am worried about someone saying I have to replace the entire system and getting scammed. Thanks in advance for any feedback or suggestions.
Re: 2016 Chevy Suburban AC Blowing warm air-HELP!!!
Posted: Tue Nov 25, 2025 10:05 pm
If I understand correctly, you replaced the battery, now the A/C compressor won't engage. Before doing anything further, scan the vehicle for Diagnostic Trouble Codes (DTC's), or have it done. Clear the codes, and you'll probably find that the A/C system works again.
If it doesn't, the system might be low on refrigerant. The correct way (in fact, the *only* way) to determine whether a low-charge condition exists is to have the refrigerant recovered and weighed by a competent MVAC shop. If the charge is indeed low, you'll have to evacuate and re-charge the system to the exact refrigerant amount specified by the manufacturer.
The specs that I have for your vehicle follow, presuming both front and rear A/C.
If it has R-134a: 32.5 ounces net weight; if it has R-1234yf: 29.9 ounces net weight.
Posted: Fri Nov 28, 2025 10:46 pm
by Mark86
Jump starting newer vehicles can cause all kinds of weird electrical issues. I would disconnect the battery overnight and reconnect in the morning. Turn the key on, but don't start the engine. Just let everything power up.
I find it unlikely the AC worked just fine then after the jump it doesn't. You say the ac clutch is engaged, if so it's pumping refrigerant.
