high side pressure is even with low side.
Posted: Sun Oct 19, 2025 9:25 am
Hi all. I was My low side pressure is 40psi and same with the high side. The compressor is kicking on but doesn't seem to be compressing. Is the compresor bad?
FWIW- I was recharging the system and I only put 12 Oz in because I was trying to track down a leak (found it) using dye. They say the system could be clogged, but I have a new dryer and cleaned out the ac components minus the evaporator under the dash. The compressor kicked on and it didn't change the high side at all, so I didn't bother putting more r134 in. Thank you.
