No cold air 2014 Buick Regal 2.0T
Posted: Sun Aug 10, 2025 6:29 am
My son said the A/C quit. Sure enough, no cold air. The system has/holds pressure based on the strong PSST from the hi side valve. I wish i had found my duffer type pressure gauge before i started the car and checked to see if the compressor was running- it was, and when i turned off the A/C it stopped and when i turned it on it started again. It wasnt cycling on and off. It has dual climate zones but i had them synced and in auto mode. I turned the temp all the way up to hi and then all the way back to lo. The car cycled the airflow from dash to feet and back to dash as i did this. I took a pressure reading at the low side valve and it was about 90, (in the redzone )while the ambient air was 80. I did not feel any of the lines getting cold or hot.
I believe i have a working clutch and compressor based on this mornings observation (adding to what i observed last night). So, updating what i know: Static pressure in system after sitting overnight and at 70 degrees ambient is 65. When car was on and running(last night), the AC set to on the clutch would engage and pressure was 90 at 80 degrees ambient. The AC lines were both the same temp. I am assuming based on all info at hand now that the clutch and compressor are working. What is the most likely culprit, how difficult a job?
