Ford Foxbody possible system blockage
Posted: Wed Jul 30, 2025 8:06 pm
Hello,
I am unsure what to try next. I'm working on an 80's mustang with the orifice/ accumulator type AC system. I currently have all new lines (3) on it, new condenser, evaporator and compressor. I put around 8 oz. of PAG oil in between the compressor and lines. I vacuumed it down to about 30" and it held for hours. I added about 2 cans of 134A and initially I had a very high (like 350 psi) high side. Now I can't remember if my electric fans were on at that moment because it's possible engine temp wasn't high enough and I know I need to address that to have them on when AC is powered. So it's possible I didn't have any airflow across the condenser at that moment. Anyway the pressures leveled out to around 274/38 at an ambient of 93 with a temp drop of about 27-28 degrees below ambient. The next day it wouldn't blow cold, started cycling, high side went between 150 to 200. I suspect maybe my conversion fittings leaked, but I think I have a blockage because when down it held around 100-120 high side and only 5-10 low side. I thought they should be equal? Prior to replacing compressor and evaporator it wouldn't hold vacuum for more than a few minutes, I made the mistake of using compressor air to see if it would hold that. So when I replaced evap & compressor I also replaced the accumulator again. So I thought maybe that dirty air clogged the orifice but when I replaced the liquid line for the second time I didn't see that and there was pressure trapped in the liquid line even after the system was empty. Sorry for the long post but I'm stumped. Thank you
