45lbs. R134a cylinder help?
Tyran7615
Post by Tyran7615 »
Im looking for Info on Bulk R134a Cylinders (45lbs). My shop ordered 2 and didn't realize they were bulk cylinders.
Does anyone have any experience with these, and is there a way to hook them up to a machine to refill the internal tank cause I've seached everywhere and cant find anything. They have a vapor and liquid valve as well as a CGA 660 male fitting. If anyone has any info how these are used it will be much appreciated cause we cant sent them back.
Re: 45lbs. R134a cylinder help?
We dealt with such cylinders in the chemistry lab. You'll likely need a regulator with a CGA 660 fitting. Or, if you have a regulator (like a nitrogen regulator), you should be able to unscrew the existing fitting and screw in a CGA 660 fitting.
