I have a 55 Thunderbird. I installed a Vintage Air AC kit. The temp gauge goes very high after driving with AC on when temps outside are 85+. I occasionally get vapor lock. The car does not boil over. I've measured temp of top rad tank and it seems to hover at 200 (-/+ 10)
I had my original radiator re-cored (3 row), I purchased an aluminum 2 row it may have made a small improvement
I upgraded the fan (electric puller in front of rad, holds a piece of paper against the grill when on), upgraded water pump, tried 4 thermostats, check head gaskets, removed freeze plugs to inspect and clean block water passage ways.
Is there anything I can do to the AC system to produce less heat under the hood?
Car running hot since I added AC
Re: Car running hot since I added AC
Confirm that the hoses for the radiator are the way they are supposed to be.
What kind of fan shroud are you using?
Adding to the above suggestion and question, are there "springs" inside the radiator hoses to keep them from collapsing and partially blocking coolant flow?
You might also consider adding an additional, temporary temperature gauge to verify that the original dash gauge is accurate.
Vapor lock can often be cured by insulating the fuel lines (and fuel pump, if necessary) under the hood.
Radiator hoses are Ford repros. Lower hose has a spring in it. I am using a 16" electric fan with a full shroud. Fan comes on with AC and/or sensor in radiator
I insulated all the fuel lines in the engine bay and at the tank were one of the lines crosses the exhaust.
A normal A/C system will only increase the operating temperature by 10 to 15 degrees. 98% of the time, when we had our shop, overheating had nothing to do with adding an A/C system. What has Vintage Air's tech support suggested? You would be surprised at the different CFM in electric fans. Get a Spal or go back to a direct drive fan. That is, if the cooling system is up to par.
Ditch the electric fan and get the original clutch fan and shroud. Most manufacturers had a different fan for AC cars than non AC cars. Ie, 7 blade vs 5 blade.
That’s a tricky one, especially since you’ve already done a lot of the right things.
From what you’re describing, it honestly sounds like the cooling system is just right on the edge, and the AC is pushing it over when it’s hot out. 200°F isn’t crazy, but with AC + 85°F ambient, it adds up fast.
One thing that stands out - if your fan is mounted in front (pusher), you might get better results switching to a proper puller fan behind the radiator with a full shroud. These cars really benefit from clean airflow rather than just more airflow.
Also, the condenser plays a big role here. If it’s a basic/older style, it could be dumping a lot of heat into the radiator. A parallel-flow condenser can actually help reduce that a bit.
Since you mentioned vapor lock too, I’d definitely look at fuel line routing/heat shielding — the added under-hood heat from the AC can make that worse even if coolant temps seem “okay”.
You’re honestly not far off. Feels more like small improvements stacking up rather than one big fix. Would be interesting to know how it behaves at highway speed vs idle
