Good evening all.
Seeking some advice...I'm working on the subject line car and have put in new parts (compressor, liquid line w/ o tube, and accumulator) after getting the report that car slowly was losing freon over time.
Vacuum test did not hold, dropping about 1-2 mmhg in 4 hrs. Can see periodic wisps coming out of vac pump...
Added dye with PAG46 oil to help find leak. I began charging the system with the intent of getting enough inside to locate dye leak, then recover at shop to work on leak. With a vacuum on the system, I bled line and added 12oz R134a, getting to about 80 psi static pressure engine off. Ambient is 76F.
Started car and had can in some water with a rag, pressure rose to about 85 psi... and compressor is not turning on.
Underhood sticker says charge level is .96 kg which I estimate at 2.16/2.2 lb/26 oz (correct?).
*Later edit: the headache, heat and anger must have addled my brain. I was using the 12oz can as my pound instead of the 16oz pound standard...
.96kg should be what I kept seeing online @ 34 oz.
Edited further below.
I still would like to know when I could expect the compressor to kick in. If I haven't destroyed it by stupidity.
Impatience unfortunately did prevail here, as I jumped the compressor to move the dye around to find the leak. Stablized at about 18 psi lo side, 150 psi hi side, then with compressor off, stabilized at 92-93 psi both.
I jumped it again after looking around with the UV light, not seeing the leak. This time lo side 10 psi, hi side kept climbing at 225 psi which concerned me and I quit. At last I located the leak on the liquid line from compressor but now am concerned I may have done wrong by jumping the compressor. By this time, the can is empty and compressor still sits still. Pressure stablizes at about 85 psi both sides (I presume I lost some pressure due to leak). I know I'll need new lines now but am concerned there may be other problems here.
I did jump one more time, getting about 15 psi lo side and about 200 psi hi side.
Questions:
-The stable 85 psi seems high...should the compressor be running by now, or do I just need more freon? At what amount should I expect it to turn on, if that can be known?
Very grateful for any advice and recommendations. If there were actions I took that I should not have, please advise on this as well...I want to work on these in the correct way. This is a charity case for a friend...trying to save her money but this has been a real headache.
2003 Ford Taurus - Compressor not engaging
Re: 2003 Ford Taurus - Compressor not engaging
Regarding the previous post:
1. Is it abnormal that the compressor is not clutching in with 12 oz of freon and a reading of 85 psi on both sides? (Ambient 76F). Dynamic pressures in previous post.
2. Is 12 oz in a 34 oz system enough to get the compressor clutching in?
Concerned that I've got a bad switch or some related condition that is not met.
3. For future reference, what else would the system use besides pressures, to allow compressor clutch operation?
Thanks for any assistance. Trying to get a better working knowledge on AC systems...
If you were reading 85lbs at rest that is plenty of pressure to activate the clutch cycling switch. Did you remember to install the old switch from the original accumulator or install a new one? Did you remember to plug it in? There is also another switch I believe on the compressor manifold. Make sure that is plugged in. You can try unplugging the cycling switch on the accumulator and jumper the harness. If the compressor engages you likely have a bad cycling switch. That is if you do actually have 85 pounds of pressure in the system. Do NOT try to jump the switch at the compressor. That switch is sending a varying low voltage signal to the PCM.
One other note. If there are any drivability codes present the PCM may not be allowing the compressor to come on.
Thanks very much for your response.
Yes, moved the old cycling switch at the time of replacement, and it was indeed plugged in during testing.
The one on the manifold is plugged in as well.
Good to know, I won't try to fiddle with that one, but can it be tested a different way, ohms or something?
Good idea to jumper the cycling switch, I'll try this first.
There is an intermittent small evap leak code, which was not present during AC replacement and testing.
Thanks very much for your ideas. Hoping this doesn't get too much more involved...
At 76*F the pressure inside the cans or tank will be 80 PSI according to the PT chart. This PSI is without the compressor doing anything. So, 85 PSI doesn't mean much. IMO I believe you need more charge. I would start by adding another can
Thanks very much for this.
I've been reading Ford Taurus forums to try getting ideas on this specific car, and there is opinion there that 2 cans may be needed to get it clutching in.
Some are even saying they could not get automatic clutch operation without jumping the compressor so they could get the second can in, which sounds odd.
I would think it should not be necessary to manually activate an AC compressor in order to charge it, seeing the system is safeguarding itself by not allowing operation on its own. Incorrect thinking? Opinions?
I'll try to get another can in it and see if it kicks in. At 1/3 charge, I suppose it isn't unreasonable that the system doesn't want to work yet.
But I doubt I'll be able to get the 2nd can in there without jumping it to take in the freon, which I'm not certain is correct practice...my mind is running in circles.
Thanks again.
Thanks again.
Please recall that a pro would use an AC machine with a 30# bottle and just dump in the factory charge. 99.999% of the time this is sufficient for the comp to start.
A couple of additional observations and suggestions:
1. Never "jump" anything, especially by forcing the compressor to run.
The main problem with that is oil circulation. If the system is below the pressure threshold for the compressor to engage, by jumping it, you're also forcing the compressor to run with little to no oil. Just like an engine, the compressor won't last long under conditions of oil starvation. In this case, the compressor might already be ruined depending on how long you forced it to run.
2. If this car is located in an area in which chemicals are used in Winter to melt ice and snow, you might have one or more pinhole leaks in any lines that are routed down low, or at the bottom of the condenser. Check these areas carefully using a "sniffer" rather than the UV dye method, which might not show anything.
Thank you John.
Good info to know. You were spot on with your suggestion of where the leak might be. This car had indeed been up north and the leak was right out if the compressor on the high side, very small.
I will plan not to jump a compressor again...
On the original problem, I believe the clutch cycling switch on the accumulator was not making good contact with the valve beneath it. Some adjustment solved it.
However, a worse problem has developed.
After charging the system to about 34 oz per sticker, ending with pressures of about 45/225 lo/hi in 87F ambient at idle, the system vented through what looks like a relief valve which is installed just out of compressor hi side.
It did this when I got to about 2000 RPM, starting down the street to return the car.
Going back over the process...started with a vacuum, bled can 1 and opened lo side. (This was before realizing cycle switch wasn't connected right). Engine off, pressure built to about 110 psi over 15-20 min. Was trying to be patient this time in case I had rushed the last time. Started engine and commanded AC, no clutch response and after a while I jumped the clutch cycling switch to engage compressor. After doing this several times is when I fixed the switch contact problem and it clutched in on its own.
2 cans later got me to the pressure above. I remembered to air bleed each one.
I thing I forgot: to run engine at 1800 RPM while charging.
Besides the last statement, what did I do incorrectly here, and why is it venting with what should be the correct weight of charge?
Sorry for the long post.
Thanks for any help.
