Sourcing R12 240sx compressor
PromiseRing
Post by PromiseRing »
Hey guys, trying to help a friend with his 92 Nissan 240sx hatch. Replaced the drier and vacuumed and charged by weight with r12, but compressor doesn’t compress. I’m having a problem sourcing any type of replacement compressor. I’ve checked rock auto as well as our ACkits.com link but to no avail.
We tried another used compressor that ‘felt’ like it had compression, but it also did not work. It will not build head pressure.
Am i screwed or are there any compressors that i can make work? Thanks in advance.
Re: Sourcing R12 240sx compressor
Did you call Tim at ACKits.com to discuss? He might be able to help you.
Why not convert the system to R-134a rather than keeping it R-12, which is extremely expensive and hard to find?
JohnHere wrote: Mon Jun 23, 2025 5:51 am Did you call Tim at ACKits.com to discuss? He might be able to help you.
Even if a new replacement compressor comes filled with PAG oil, you can drain that oil and flush with R-12 type mineral oil by rotating the compressor drive plate a dozen times, then dumping that, then repeating, if you don't want to go to R134a.
I had to do the flush thing on the new compressor (bought through Tim at ACKits in 2014) for my 1988 Mazda truck, because that came filled with PAG oil, and I stayed R-12. Back then I was working, and could test the oil type at work in 2 minutes.
If someone calls, they will need to leave a message. I screen all calls anymore. The telemarketers and people just using our resources for free has gotten out of hand. Sad position to take, but better mentally than being pissed at the 4th caller that day asking how much oil should I put in the compressor they got off eBay. I'm 61 now, past the prime of chasing every sale. If the customer wants to spend a moment to leave a message, I usually respond via a text.
As for this issue, no one makes compressors anymore. If the core is good, it turns internally. We can have the compressor shop rebuild the customer's core. Same as buying the reman on our website, plus the freight to send it to our compressor shop.
PromiseRing
Tim wrote: Wed Jun 25, 2025 7:01 am As for this issue, no one makes compressors anymore. If the core is good, it turns internally. We can have the compressor shop rebuild the customer's core. Same as buying the reman on our website, plus the freight to send it to our compressor shop.
Hey Tim, how can i get more information about sending a core in? We have roughly 3 or 4 of these compressors and are just hoping to have one good unit to install. The next best option is looking like using a 1998 Maxima compressor along with an S14 bracket. Trying to avoid a hodgepodge unless necessary.
JohnHere wrote: Mon Jun 23, 2025 5:51 am Why not convert the system to R-134a rather than keeping it R-12, which is extremely expensive and hard to find?
Without also swapping the serpentine style condenser for a parallel flow, i would be sacrificing quite a bit of capacity and efficiency from what I’ve read.
I will flush the existing condenser and plan to replace the TXV and evaporator coil because i am tired of opening this system up :lol:
Internals of your core have to turn. Then we treat it as a Reman unit on our website. Additionally, you would need to send the core (s) to our compressor shop. They have the final answer on whether it is rebuildable and whether it would pass the post-build tests.
Your first step is to inspect the internals of the compressor. Not the pulley, but the front hub is turning the internal components.
PromiseRing
We installed a compressor that was for a 1998 maxima (I think). Drained the pag46 and swapped in ~7oz of mineral oil. Also flushed condenser, installed new evaporator coil (dry), and another new drier.
We bought a new TXV but it didn't fit so we had to reuse the original. It had particulates in it but I flushed it clean as good as I could. Pulled a good vacuum and charged by weight with r12 but vent temp barely changed. I don't have an adapter to monitor liquid line pressure but vapor saturation stayed around 28-34F. Suction line warm to the touch so we know superheat is very very high. These TXVs are spec'd at holding about 8F superheat. Regardless, a functioning system will have a suction line that's cold to the touch.
My assumption is that our TXV sensing bulb lost its charge and is underfeeding. My thermal imagining camera shows ~34F at the outlet of the TXV, but the whole evap coil is warm to the touch.
We're going to have to try to make an r134a TXV fit.
PromiseRing wrote: Sat Jun 28, 2025 5:17 pm Without also swapping the serpentine style condenser for a parallel flow, i would be sacrificing quite a bit of capacity and efficiency from what I’ve read.
Not necessarily.
For what it's worth, until recently, I owned a 1994 Toyota Camry V6 Wagon, bought new, with a factory R-134a system (first year for any Toyota, from what I understand) that had a serpentine condenser and a R/D with a sight glass. This car regularly recorded center vent temperatures in the high 30's, even on 95-degree days in the humid South.
PromiseRing
JohnHere wrote: Sun Jul 06, 2025 8:25 pm
Not necessarily.
Impressive, but I imagine is was sized accordingly!
Your condenser might be appropriately sized as well.
In my car, I believe that Toyota used a serpentine condenser and R/D left over from their R-12 vehicles, and they cooled just fine for more than 29 years using R-134a.
