07 accord v6 low preasures
Posted: Tue Jul 18, 2023 9:55 am
by Jackb
Got a Honda accord v6 came in poor cooling. Charged several times still poor cooling. Has low gauge preasures low side 18 and hi side 75. Replaced expansion valve from the inside. Still low pressures and poor cooling. Today replaced compressor still low preasures. What am I missing
Re: 07 accord v6 low preasures
Posted: Tue Jul 18, 2023 11:24 am
"Charged several times still poor cooling" what does this mean? You charged it several times with the refrigerant amount listed on the under hood sticker?
If so you have a massive leak. There is no mention that you vacuumed the system before charging. More info is needed.
Please give year of car.
Honda AC is known to be marginal in the first place.
Normal procedure would have been to recover remaining refrigerant, vacuum, and then weigh in correct weight.
Often systems are low because of seasonal losses via hoses, comp shaft seal, etc
Posted: Tue Jul 18, 2023 1:14 pm
Well, it's an 07, and the A/C on those is usually decent.
A Parallel Flow condenser about 25" x 14". Electric fans.
Multiple charge attempts, replaced TXV and compressor. High side is 75psi.
How much refrigerant was weighed in at each charge? Any oil added?
Right now it looks like a defective service valve on the high side.
Posted: Tue Jul 18, 2023 3:02 pm
by Jackb
Right now I ordered a drier for tomorrow (7-19)thank you for your support will let you know
Posted: Tue Jul 18, 2023 5:45 pm
You have a happy parts supplier.
Posted: Wed Jul 19, 2023 12:57 pm
Any mechanic is only as good as his parts supplier.....
Posted: Wed Jul 19, 2023 1:12 pm
tbirdtbird wrote: Wed Jul 19, 2023 12:57 pm
True. Tossing parts at an issue is not what I usually suggest to customers.
