Compressor Won't Run
Dgreen
Post by Dgreen »
2005 Saturn Vue. System was empty when it arrived. It had signs of dye around the high and low connections. No bubbles at connections when I applied nitrogen to the system. Can't find dye anywhere. micron gauge starts to rise when the vacuum pump is turned off. Added dye and 1/4 oz of oil. Vacuumed and put 7 oz of refrigerant in and the compressor wont run. There is voltage at the compressor. Coil showed 8 ohms, I think, resistance.
Any ideas why the compressor won't run and any common leak points on these systems?
tony1963
Re: Compressor Won't Run
Post by tony1963 »
Use a scan tool to see what codes are stored in the AC system. On some vehicles, once the system registers a code for low refrigerant, it will not engage the compressor until the code is cleared. Start there.
8 Ohms is about 4 ohms too much. Coil may be faulty. Are you sure you got good purchase on the ground and feed wire? (ie no resistance in your connections)?
I also doubt any system is gonna turn on with only 7 oz of refrigerant. LPCO is gonna override to protect the comp
Dgreen
Post by Dgreen »
7 oz is all that would go in. It was 85 degrees out, so system pressure would be 90 or so wouldn't it? Should try to run at least a little.
Wire setup for checking continuity of the coil was pretty sketchy.
tony1963
Post by tony1963 »
You should see a low side with the interior fan running on high of about 40 psi and on the high side around 220 psi.
