10mm switch port o-ring size?
KENS80V
Post by KENS80V »
My replacement GM pressure transducer (13587668) did not come with a new o-ring for the 10mm switch port. I don’t have the original o-ring. Can anyone help with a part number or correct size/dimension.
Re: 10mm switch port o-ring size?
Hard to say what the exact size is. I keep a "problem solver" assortment of o-rings on hand for such a purpose, and try a few until I find one that appears to have the right diameter and thickness. O-ring assortments are readily available, often packaged in a compartmented, clear plastic box.
The local parts store should be able to help out. Aftermarket suppliers list the o-ring. TOYOTA #5
