2012 Nissan Pathfinder AC will not turn off
808makana
Post by 808makana »
While driving today, I noticed the AC was blowing in the defrost mode. None of the buttons will work (Fan high/low, Temp high/low, mode) does anyone know of a fix? 2012 Nissan Pathfinder LE 6 CYL
DetroitAC
Re: 2012 Nissan Pathfinder AC will not turn off
Post by DetroitAC »
Sounds normal, compressor keeps running to dehumidify the air.
DetroitAC wrote: Sun Nov 27, 2022 6:27 am Sounds normal, compressor keeps running to dehumidify the air.
Detroit means that if Pathfinder appears OK when started up without defroster on, that's how it's engineered. So turn off defroster and try fresh start up.
