Air temperaturecoming out of my car vents
notlimah3
Post by notlimah3 »
I am curious what should the temperature coming out of my vent. The temp here is 90 and 35% humidity. I find a lot of different answers. I figured would get good 411 here
Re: Air temperaturecoming out of my car vents
You posted in the wrong category.
You also should state year, model, etc. and what type of refrigerant it contains (R-12, R134a, 1234yf).
Moved it.
Once we have what Cusser posted, we can get a better idea if you are able to hook up an AC manifold gauge set and give hi and low pressures at 1500 RPM, full load meaning doors open, recirc on, max fan, and max cool setting
