Can I test a R12 system with R134a for a few minutes?
Posted: Tue Apr 19, 2022 2:46 am
I completely replaced all the ac system parts on my 88 ford van about 6 years ago and charged it with R12 and used Motorcraft mineral oil. I used a Motorcraft E6DH compressor and a stock Ford tube/fin condenser.
At the end of last year i started seeing some water dripping in the passenger floor board and the vent temps had gotten cooler. I assumed that the system must be low on refrigerant and I would need to find and fix the leak the recharge the system.
So this year when I went to use the AC, here is what it is dong:
Starting the engine and turning the ac on to max but low fan. Ambient temp 70F. I connected the gauges and purged the hoses and both gauges equaled out at about 62F but it had been around 55F overnight and so the components and refrigerant was colder then the ambient temp of 70F
Cycle time was 3 seconds on and 15 seconds off.
High side pressures were 75 to 95 PSI
Low side pressures were 39 to just over 40 PSI
A little while longer with engine up to temp and the AC components starting to warm up:
High side pressures were 95 to 115 PSI
Low side pressures were 35 to 37 PSI
I used a jumper at the clutch pressure switch, the suction side pulled down to 0 PSI at which time I pulled the jumper.
The high side went up to 115 PSI while the suction was at 0 PSI
I tried to add some refrigerant but it would not take any. When ever I would open the valve to add some, the low side instantly jumped up close to what the high side was.
Second attempt the next morning.
So this morning while the temps were still below 70F I connected the gauges and installed a jumper in the clutch connector so that the compressor would run continuous.
The low side went down to -15 so I opened the low side valve to see if it would take some refrigerant. As soon as I cracked the valve the low side pressure started climbing back up towards 60 or 60 PSI so i closed the low side and let the pressure drop back down to 0 PSI. At that point I just barely opened the low side valve till it reached about 10 PSI and tweaked the valve so it stayed around 5 to 10 PSI. At one point I placed the R12 can on the radiator hose to get the can warmer. Eventually I was able to get about 10 ounces into the system.
At the very beginning I noticed the suction line was starting to sweat a little like it did the day before. I put a thermometer in the vent and had the fan on low. While trying to get the system to accept the refrigerant, i checked the vent temp and it was about 50F. Shortly after though with the engine and radiator heating up the condenser and other components, the suction line became warm and the vent temps went back to ambient temperature of around 70F
The compressor is noticeably louder then it was last year . With the extra refrigerant in the system the compressor is cycling even shorter, about one second
The high side pressures are 105 to 125 PSI
The low side is now bouncing 36 to 39 PSI
The readings were taken with the engine up to temp and the ambient air temp about 70F
A local shop, without looking at the van, said that it was just low on Freon and that he would pull out the R12, add a conversion kit and fill the system with R134a. So I ask about the oil and he said they would just add a couple of ounces of rag oil! I left telling them I would have to think about this.
So I have a r12 charge on hand for the system but I certainly don't want to waste it. My main question is this.. for testing purposes, can I vacuum and charge the system with R134a and dye and then run the system just long enough to get some readings verifying if the compressor is good or bad without damaging the compressor? This would also disburse the dye to help look for a leak, if there is one. Also want to inspect and replace the orifice tube prior to vacuum at this time..
I would be more then happy to convert it to r134a if I could locate a parallel condenser. There seems to be quite the shortage on older condensers these days.
Any and all help and advise is more then welcome!
Thanks all.
Charrie
Thanks all.
Charrie
