VW A/c help
Dr.robotnik
VW A/c help
Post by Dr.robotnik »
Can anyone help with an A/C problem?
The system has just been charged with new refrigerant and there are no leaks.
When I press the AC button, the clutch engages and the compressor spins, however the blowers in the car don't get any cooler.
The auxiliary cooling fan is dodgy which I'm in the process of replacing, but the larger fan works fine.
Very much a rookie in all this, any suggestions greatly appreciated.
Thankyou
Re: VW A/c help
? model ? year
who charged?
who determined no leaks?
was system evacuated before charging?
why was system worked on in the first place? failed compressor? or?
etc
Need as many details as possible
Dr.robotnik
Re: VW A/c help
2002 New Beetle 2.0l petrol
Our local garage filled it with refrigerant and confirmed there weren't any leaks in the system, however they couldn't get the AC to run cold even with the refrigerant in the system.
We had the refrigerant filled to see if that was why the AC wasn't blowing cold but it seems there's another issue somewhere.
Re: VW A/c help
If my vehicle, I'd measure and post both low side and high side pressures at about 1800 rpm.
And after a couple of minutes I'd feel if the line from the condenser was hot, and if the line coming from the evaporator was cold.
Re: VW A/c help
Is the clutch actually engaging?
If so the next stop is the control valve
Dr.robotnik
Re: VW A/c help
Thanks for the suggestions.
Yes the clutch definitely engages on the compressor.
I will measure the pressures next week and asses further.
Many thanks
Re: VW A/c help
Dr.robotnik wrote: Sat Aug 07, 2021 5:08 am I will measure the pressures next week and asses further.
Some asses are bigger than other !!!
Dgreen
Re: VW A/c help
Post by Dgreen »
I’d say control valve on the compressor. Pressure readings will help confirm this.
Dr.robotnik
Re: VW A/c help
Thankyou
Is this control valve the same thing as the pressure relief valve on the compressor?
R
DetroitAC
Re: VW A/c help
Post by DetroitAC »
It's not the same as the PRV. I think your compressor is a Sanden SD7V16, but seems like you are in the UK since you said "petrol", so it might be different. SD7V16 was very popular back then and they are good compressors, durability of the Sanden wobble plate design and is also a variable.
The bad news is the control valve is buried inside the compressor. I think it's attached to the valve plate, I can't remember if the body castings are o-ring sealed or metal gaskets. Either way it's a low probability you would be successful in replacing that valve and getting it back together without leaking.
