No gauges pressure changes after adding r134a
Posted: Fri Jul 02, 2021 2:02 pm
My car is a 2005 Pontiac Grand Am GT 3.4l engine. The charts I looked at said 45-50 low side and 175-220 with ambient temp. around 80 degrees fh. my pressures were 30 and 125. I added a 12 ounce can of r134a and the pressures stabilized at the same readings 30 and 125 just like when I started. The air feels colder, the thermometer reading is between 43-45 degrees the Freon was installed at normal idle. Thanks for all help!
