No Measurable High Pressure GM A6 Replacement
Posted: Fri May 28, 2021 1:30 pm
				New Member here with a very strange situation. Expert advice appreciated.
It gets more interesting - so please read it all. Surprise ending, even.
I've replaced my A6 factory compressor on my '67 Camaro 327, along with all components except for evap and condenser and muffler. When it was open I flushed the entire system with solvent, then with air. Car had previously been switched to R134a. I did install the appropriate PAG 150 oil. (Confirmed amount)
I vacuumed it down with no problem. High side gauge drops into negative territory and Low Side drops almost to -30. So far, so good.
Begin installing R134 as normal, and I see Low side readings around 20 - 30. With the POA Valve upgrade it is necessary to connect the POA switch to get the compressor going at this stage. After the first can of R134 flows in, I see no High side pressure at all. This is strange, as we'd expect to see something at this point. Beginning the second can of R134, the compressor clutch starts screeching! Shut down the compressor and let things rest a moment. Still no High pressure. It is still in the negative as when it was vacuumed! Yes, it's not Zero. It is still negative! (Red valve on gauge remains closed always)
Turn compressor back on, and in about 10 seconds I get the screeching clutch. As a test, I remove the jumper on the POA switch to let the compressor attempt to operate normally. Still attempting the second can at this time. Well, as you may expect, the negative pressure rises and falls rapidly, with the POA switch doing its thing, cycling the comp on and off very quickly! Every 2 seconds or so we see the Low side pressure change, which of course causes the comp cycling. As the cycling occurs, we get an occasional momentary screech. When comp turns on, negative pressure drops to near zero, but jumps to around 50 - 60 when pressure switch opens. Cycles continuously.
Still no High pressure measured. Still in Negative! Quick observation makes us think compressor is pulling negative on the Low side and nothing happening on the High side. I then talked with the SMP guys in TX - and their expert said there had to be some sort of restriction in the system - or a defective compressor. I am baffled that even with a restriction, wouldn't I see some high side pressure since the muffler and port is connected right there to the High side of the compressor?
But no - the High gauge still reads below Zero! And Low Side static pressure is 120psi at this point. I opened the low side to relieve the pressure before taking next step. Note: After low side is bled to zero, high side gauge still below zero. The next item is the surprise ending.
Next step: Check compressor port connector for blockage or whatever. Remove the block-type connector which opens both sides of compressor. Nothing unusual found. High side gauge still showing negative, even with compressor port connector wide open. Huh? Is there a blockage in the muffler? Inserting a flexible plastic probe allows me to go all the way through the muffler and into the hose going to condenser. No blockage. Gauge still shows negative.
Open high side port at the gauge set and the negative reading disappears as the vacuum (still present up to that point) dissipates. What's in that muffler? A valve in addition to the Schrader? Something else blocking port access inside muffler?
Why no High pressure at all? Why the continuous negative reading while R134 was added and compressor running? Why compressor clutch screech? I'd have to guess the clutch screech is a result of comp attempting and being blocked by super-high internal pressure? Can't let that happen long or clutch burns up and/or compressor too. Only a couple seconds.
First possibility was gauge set not opening Schrader in muffler, but no that's not the problem. Still uncertain what's going on, but one thing that seems obvious is that the high side port is not showing what's going on in the high pressure line between the compressor and the condenser. Vacuum down again, and when we put half a can of R134 in, the pressure switch begins to cycle - with the pressure dropping to zero when the compressor kicks on for one second -- then up to around 50pis when the compressor is off. This behavior repeats continuously, and we still have no high side reading at all. When the engine is shut down and things go into steady-state, we see pressure on the low side but none on the high side. But if we do nothing for two hours we begin to see some static pressure on the high side. Is there some sort of blockage between the port and the main line in the muffler? Get this: When we reach steady state and finally see some pressure on the high side port, we can disconnect the compressor port hoses and of course the low side pressure drops - but the high side pressure does not! This again makes us think there's something terrible wrong in the muffler. Reading some static pressure on the High side when system is open! Open red hose to gauge, it drops -- reconnect hose to gauge and it very slowly builds.
Help!!
Help!!
