gauge readings
penguins25
gauge readings
Post by penguins25 »
my ac in my 08 mgm doesnt work on normal ac
it does work somewhat on max ac
i put my guages on it and this is the readings
low side read 125 constant
high side was going from 200 to 300 cycling
Re: gauge readings
What exactly is an "mgm"?
It sounds like a coupler malfunction. Low side.
penguins25
Re: gauge readings
mercury grand marquis
penguins25
Re: gauge readings
whats a coupler?
Re: gauge readings
The low side fitting on the hose does not sound as if it has the proper connection.
Re: gauge readings
penguins25 wrote:my ac in my 08 mgm doesnt work on normal ac
bohica2xo wrote:What exactly is an "mgm"?
Penguins, you assumed we would know what "mgm" means????
penguins25
Re: gauge readings
please help yall
i really want to fix my ac and dont know where else to go
penguins25
new readings
just went out there and put the gauges on and here is what i got
low side 75-150
high side 300-500
both sides cycle back and forth through them numbers
my ac blows cool not cold
edit:
these readings were taken on max ac
theres a normal ac setting i can put it on but the ac doesnt blow as cool on this setting
i can go take anorther reading on normal if this would be helpful
Re: gauge readings
Readings are too high. Spray the condenser with a water hose while monitoring the high side pressure. Does it drop like a rock? If so, start by checking airflow across condenser. Check the cooling fan also. If the high side drops, does the low side drop also?
penguins25
Re: gauge readings
i put the gauges on and got the water hose
its doing the exact same thing as before its going back and forth between
low side 75-150
high side 300-500
the water on the condenser does not drop the readings
