Ford F-250 A/C blows cold then hot
Posted: Sun Mar 19, 2017 6:56 pm
by Kennyanddawn3
I have a f250 7.3 diesel that blows cold air for 20 minutes or so then turns warm and humid ???? Then will blow cold again back and forth checked freon level it is fine has been doing this for a couple of years any advice shop can't figure it out
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Re: Ford F-250 A/C blows cold then hot
Posted: Tue Mar 21, 2017 1:58 am
by Dougflas
When it starts to blow hot, is the front of the compressor turning? Fords had a history of bad cycling switches.
Posted: Sat Apr 15, 2017 4:36 am
by DarrylS
I would be tempted to just replace the low pressure switch that is quick and easy. The problem must be really intermittent if an AC shop cannot diagnose? Just need to take pressure readings and keep an eye on compressor engagement.
Posted: Wed May 03, 2017 11:49 am
Check the compressor clutch gap.
