Leak
Re: Leak
Tim, looks like you came thru again.
Someone needs to tell him that his buddy that makes hydraulic hoses will not have the proper crimping rig for AC, and it will leak. AC requires so-called bubble crimp
Re: Leak
tbirdtbird wrote: Wed Jun 01, 2022 7:21 pm Tim, looks like you came thru again.
To be fair, I misunderstood what he was asking today. I was picturing a long all-alum line.
Re: Leak
Tim wrote: Wed Jun 01, 2022 7:11 pm Is he looking for a discharge line? I had comp to evap.
Discharge Line 3.3L
57-0246
Yes, he is looking for a discharge line for his V6 VG33 2004 Frontier. Notice that 57-0246 does have the notch at the condenser fittin
Re: Leak
Like this? LOL
Re: Leak
Tim wrote: Wed Jun 01, 2022 7:45 pm Like this? LOL
Like that !!!
And it looks - to me - like the 2004 Frontier uses same condenser whether 2.4 L4 engine or 3.3 V6 engine. So the horizontal line that runs over top of the condenser doesn't need to be monkeyed with, slides through the notch in the high pressure line.
Re: Leak
Cusser wrote: Wed Jun 01, 2022 7:52 pm
The call for a different item number on the 2.4Ln Both have a notch in them.
tnfarmboy
Re: Leak
Post by tnfarmboy »
It is the solid aluminum liquid line from the condenser to the evaporator. I looked online and couldn't find one. It's worth looking some more I'm all for saving money. If I had a part number it would help, but I haven't even been able to find that.
Re: Leak
Did you call Tim back???
Re: Leak
tbirdtbird wrote: Thu Jun 02, 2022 12:05 pm Did you call Tim back???
I posted links with images. He should be able to tell which one. If none of those, I have no other options.
Re: Leak
tnfarmboy wrote: Thu Jun 02, 2022 12:03 pm It is the solid aluminum liquid line from the condenser to the evaporator. I looked online and couldn't find one. It's worth looking some more I'm all for saving money. If I had a part number it would help, but I haven't even been able to find that.
OK, your vague descriptions have confused most of us.
I now think you are looking for Nissan #92440-1Z701, the solid aluminum pipe that runs horizontal over the top of the condenser, which seems to run about $160 online.
