No Measurable High Pressure GM A6 Replacement
1GCamaro
Re: No Measurable High Pressure GM A6 Replacement
Post by 1GCamaro »
If I go with a different compressor will I need to replace the Drier again? It is new but probably has a little oil in it from the attempts with the rebuilt A6. I've flushed the system again but of course did not flush the Drier. When I flushed this time, I once again had no oil in the condenser but a good bit in the evaporator.
I'll replace the Drier again if really necessary but if that's overkill I'll keep the one that's in there.
If while flushing the other components, you took out the R/D and left it setting out uncapped for an unknown amount of time, I would replace it again. If you took it out, capped the openings while you were flushing, then upcapped and immediately reinstalled it, I think you'd be safe in reusing the existing R/D.
1GCamaro
Post by 1GCamaro »
JohnHere wrote: Mon Jun 07, 2021 10:06 am If while flushing the other components, you took out the R/D and left it setting out uncapped for an unknown amount of time, I would replace it again. If you took it out, capped the openings while you were flushing, then upcapped and immediately reinstalled it, I think you'd be safe in reusing the existing R/D.
Thanks - That's kinda what I was thinking. It has been open to the air for a few days, so I'll pick up another one.
