Reviving 1984 Isuzu PUP AC
GeraldK4nhn
Re: Reviving 1984 Isuzu PUP AC
Post by GeraldK4nhn »
I was finally able to locate a shroud for the Pup and that really made a difference to the pressures. There's not tac, but with about a 1,ooo to 1,200 RPM , the outside temp was 92 degrees. With a fan 6 feet in front, the high side was 205 and the low side was 48. The temp out the vent temp was at 50 degrees. There was so much air flowing thru the condenser that it had no problem sucking a shop rag against it and holding it there. Now to put it ion the road and see how it does. Freon flow through the sight glass was full and smooth flow. Thanks guys.
Gerald K4NHN
Cayce, SC
Good, hope that gets you "there".
