High efficiency condensor for C5 vette
zz28zz
Re: High efficiency condensor for C5 vette
Post by zz28zz »
Cusser wrote: Fri Sep 25, 2026 2:04 pm
zz28zz wrote: Fri Sep 25, 2026 12:11 pm Is it common for 12oz cans to be short on refrigerant? I've never heard of that.
On the other hand, I also feel that one can only deliver about 11 oz. from such cans into the system, from venting the hoses to some remaining inside the can.
I can see that happening with hose purging. It would be interesting to measure how much is left in the can once it's down to ~25 psi or so.
I'll be using a scale this time.
zz28zz wrote: Fri Sep 25, 2026 5:59 pm I can see that happening with hose purging. It would be interesting to measure how much is left in the can once it's down to ~25 psi or so.
If you're looking for a refrigerant scale, choose carefully because some professional scales will accommodate a minimum of a 30-pound cylinder, not as small a container as an individual 12-ounce can.
