Page 2 of 2
Re: Importance of "dust caps" for schrader valves
Posted: Mon Mar 16, 2026 2:58 am
I can't speak for GM Tech. As for the plastic caps withstanding 300+ PSI in MVAC systems, they are indeed intended to withstand such high pressures. In fact, the robust threaded design of the caps is sufficient for more than 400 PSI on the high side. Otherwise, most trinary (safety) switches wouldn't be factory-set to that high a limit. That's also why the caps have a rubber element or washer or seal in them, as GM Tech said.
Posted: Thu Apr 02, 2026 3:19 am
by GM Tech
Yes, I worked alongside the Hose and Lines Engineers when trying to solve a/c systems issues and they were the ones who designed the caps to hold back minor pressure leaks that got by the shraeder valves. If I want to test my leak detector, I always pop a cap and then sniff the port. It always goes off!!
