Page 2 of 2
Re: R-134A System Schrader Valve Core Size
Posted: Fri Jul 26, 2024 9:29 pm
by jz57
Pix are added
Posted: Fri Jul 26, 2024 9:36 pm
by jz57
Thanks very much for the help
tbirdtbird wrote: Tue Jul 23, 2024 6:11 am Tim, can you help with posting his images?
To the poster, you hit the Attachment tab at the bottom left, and then ‘add files’, then follow the prompts, it should work.
I myself was never able to get the drag and drop function to work.
JohnHere wrote: Thu Jul 25, 2024 2:27 pm The Forum software probably is preventing the picture from posting if it isn't 256KB or less in size.
Posted: Fri Jul 26, 2024 9:52 pm
You only have half of the tool set. The other (missing) half will be able to accommodate the larger Schrader valves pictured. A tool supplier for professional MVAC technicians should have them or can order them for you. The knurled double-sided tool is for removing and installing the Schrader valves after the refrigerant has been recovered and the system is empty.
