My new motorhome needs Air Con!!
rsamsel5614
Re: My new motorhome needs Air Con!!
Post by rsamsel5614 »
I did not. Like I said....I followed the instructions on the can.
Then you injected air.
I am gonna step aside and let others take over
rsamsel5614
When I don't know how something works I follow the instructions. I get that it's easy to consider me an idiot for using that stuff. It's not possible to be knowledgeable in every area. Today I honed the cylinder of a KLR and fixed the clutch chudder on a DL1000. I'm not stupid in terms of working on vehicles and I'm not financially capable to take all my toys to the shop when there is an issue.
Would you rather someone hit the forum without trying what seems like a likely fix first?
rsamsel5614 wrote: Thu Jun 24, 2021 9:27 pm When I don't know how something works I follow the instructions. I get that it's easy to consider me an idiot for using that stuff. It's not possible to be knowledgeable in every area.
Like many others, you were seduced by AC Pro advertisements and "instructions" on how easy AC fixin' is. It is not so easy, and many times specialized equipment is needed.
Like I mentioned before, proper reclaim, vacuum, and recharge is the correct way to get back on track. In the past, I have read Autozone my rent the tools needed to do this. Suggesting any other approach is just wishful thinking and improper in my opinion.
PS: No lecture. I've been doing this for a long time. I read these same posts daily if not with calls on the phone. I bought this from Rock, ebay, Amazon, and so on. Now, what do I do with it. People want to save a dollar then want free tech support from me over the phone. So when I get short in my answers, it's not just you.
For the record, I have only worked on one system that had sealer, but I did not know and the owner did not say.
Pressures were not even close and of course it would not cool. After some investigation, I removed the hose from the TXV.
What a god awful mess in there! Every part was contaminated with this nasty goo that clogged everything. I had never seen anything like it.
Bottom line, I had to replace every single part of the system incl the condenser and evap, cost the guy a bundle.
Never again. And I refuse to work on his cars now
rsamsel5614, did you come up with a plan of attack?
rsamsel5614
My plan of attack is to take it to the shop next week. It doesn't seem like I have other options. It's going to be 112 here on Monday which is a bit too warm for no ac. For now I'll be running the generator and the roof air when running down the highway. It just sucks because it had cool air and I made things worse. I'm really upset with myself.
Please let us know how it works out, it will help all the current and future forum members, good luck
Don't be upset, you learned and the error was not massive.
