72 Corvette POA Valve
Re: 72 Corvette POA Valve
Sailfish95 wrote:Tim,
Thanks for the advice. I order the injector you recommended, with some mineral oil ID: 12738 . Is there a method I should follow when injecting the oil;
inject into the low side on the POA valve?, compressor off or on? How much oil injected per application?
Thanks for you help
Ed
Thank you for your support. The order has been processed shipping directly from the manufacturer. Should be there first part of the week.
Tim wrote:
Sailfish95 wrote: Is there a method I should follow when injecting the oil;
Thanks for you help
Ed
Using that oil injector you force the oil in by turn the hand dial. So compressor Off.
