Sourcing Quality Compressor
PromiseRing
Postby PromiseRing » Mon Oct 01, 2018 7:44 am
1990 Volvo 740GL, NA, auto, SOHC, originally r12 car.
Hey guys, not sure if this is the appropriate subforum for this topic but if not, please move it accordingly.
My fiancés ac compressor is leaking oil/refrigerant from what seems to be the front and rear of her compressor. Rather than pulling it apart and fiddling with seals, I plan on simply replacing it with a good quality unit. I'm wondering where I can find a good quality compressor. I recently fixed her AC this past summer by simply replacing the R/D, orifice tube, and filling with ES12A (this was all prior to research! I now know that flushing is ideal in case someone had filled with r134-a before, and we don't like alternative refrigerants here).
Anyway, rock auto is showing a four seasons 58521 as a replacement. Is this a quality unit? They also have a UAC CO2011Q. Not sure which I should use, we are simply looking for longevity here.
Plan is to remove compressor, flush evaporator and condenser and lines, replace R/D again, and orifice tube, compressor, then fill with appropriate amount and type of oil and refrigerant (not yet chosen).
Been researching this stuff all morning. Car has a remanned unit on it and I'd like to replace with a QUALITY unit that I can use R12 with. They used Pag46 so the whole systm needs to be flushed.
Anyway, looks like a Seltec (Diesel Kiki) DKS15BH is the OE unit, which is what Four Seasons is supplying? Might as well order the Four Seasons unit it seems, since that is the OR part number and not remanned.
PromiseRing
Re: Sourcing Quality Compressor
Postby PromiseRing » Tue Apr 16, 2019 9:18 am
Bumping my old thread. I am thinking about just replacing the compressor shaft seals since the compressor itself works well, and it would save me quite a bit of cash. Has anyone ever replaced the seals in this type of compressor, and if so, is this something that is 'easily' doable DIY?
Here is the kit I was going to use, and was wondering if I need any additional seals/parts were needed, like where the 2 halves separate. I know I will need new pag 46 as well as well as a receiver dryer and orifice tube.
https://www.ebay.com/p/A-C-Compressor-S ... 938&chn=ps
Thanks in advance.
Postby Tim » Tue Apr 16, 2019 1:08 pm
We supply that shaft seal for a cheaper price. Plus would add support behind it over your Rock Auto and eBay purchases. Got to love the internet.
P:602-233-0090
PromiseRing
Postby PromiseRing » Fri Apr 19, 2019 12:29 pm
Tim wrote:We supply that shaft seal for a cheaper price. Plus would add support behind it over your Rock Auto and eBay purchases. Got to love the internet.
Tim, I would be more than happy to order from you:) I may need a few more parts for this compressor as well. Can I send you a PM or an E-mail?
Postby Tim » Fri Apr 19, 2019 2:45 pm
Happy to supply anything that is available to me.
[email protected]
P:602-233-0090
PromiseRing
Postby PromiseRing » Fri Apr 19, 2019 7:19 pm
Tim wrote:Happy to supply anything that is available to me.
[email protected]
Email sent :)
Postby Tim » Sat Apr 20, 2019 11:29 am
With data provided. Parts for your compressor.
http://www.ackits.com/santech-compresso ... 5bhdks15ch
P:602-233-0090
