Can someone confirm if the threads are standard direction? i.e. I would turn the lock nut counter clockwise to unlock.
Also which direction on the adjustment screw (CW or CCW) will lower the pressure?
bohica2xo wrote:DEC PAG explanation https://www.autoacforum.com/messageview ... adid=17571
Thank you for both suggestions! I will look into these.bohica2xo wrote:For heater valves on GM stuff I use a vacuum unit, like the AC Delco P/N 155536 It was used on G vans, and P vans from 1990 to 1996.
Four Seasons 74781, 5/8 and 3/4 hoses, apply vacuum to close. Stock app is 96-2000 GM trucks.TheBandit wrote: Are you aware of a vacuum operated bypass valves that would be suitable?
E38 ECM does require a/c request over the data bus but there are aftermarket solutions for this with no dash control modifications needed. On most 58x calibrations I've seen the radiator fans will operate on refrigerant pressure alone even without a/c request functional. There's also an anti-slug startup routine in these ECM cals, low mount compressor can suffer that in the right conditions.TheBandit wrote:I agree and this is my plan. Also I believe my PCM and operating system (GM E38 '07+ Silverado) would require a body control module (BCM) for the AC request, which I do not have. I would prefer to use the original controls which are very simple and setup to run the compressor continuously.bohica2xo wrote:Obviously you already know you can't use the PCM to run the compressor, because it needs the feedback from the 3 wire pressure sensor - and it wants to cycle the compressor based on that information. Run the compressor from the OEM 1970 circuit.
