I don't think you mentioned whether your truck has automatic climate control. Regardless, the following procedure has reportedly worked to reset the A/C for some owners of these trucks, and it might work for you as well. It's worth a try, anyway.
Turn off the A/C and radio, as well as the engine and the ignition switch. Open the fuse and relay box under the hood (usually on the driver's side) and pull out the 10-amp fuse marked HVAC/ECAS. Leave the fuse out for about two minutes, then reinstall it. Don't start the engine or turn on the ignition and A/C just yet.
You should now hear the amplifier (or electronic control module--ECM) under the dash going through cycles as it resets itself.
Once this sequence completes, start the engine, turn on the A/C, and see what happens. It might take a few tries at this to reset the system so that the compressor runs the way it should.
Compressor won’t stay running.
Re: Compressor won’t stay running.
Thanks, I will give that a try. It does have auto climate control.
I had tried removing that fuse, but I didnt know the rest of the procedure.
This was a friends father in laws truck. He said he put in a new relay for the ac and it started working. I change out the relay when I had it with another relay from his fuse panel. Didn’t work for me. I wonder if the auto ac just finally reset itself?
Thanks for all the help!
