Heat stops blowing through vents
Timjr88
Post by Timjr88 »
Hello, I have a 2010 Honda CR-V. When I turn the heat on in the morning it works fine for about 10 minutes then stops blowing through vents. I have replaced the blower motor and transistor and the problem still continues. The blower motor stays on but air stops passing through vents over time. I also checked the blend door motor and it’s working fine. Does anyone know what the problem could be?
